Upgrade Failed with ORA-00942: table or view does not exist – pr4_base
The upgrade failed stating pr4_base table not exists. But when we connect to SQL Developer, we were able to see the table present in the migrated schema.
[java] 2015-11-24 09:03:49,326 [ WHE-304] [ ] [ ] ( priv.management.MBeanSecurity) INFO - deny.DatabaseManagement.DatabaseConnectionDetails=true
[java] 2015-11-24 09:03:49,621 [ WHE-304] [ ] [ ] (riv.management.MBeanManagement) INFO - MBean Management (Web) initialized for DefaultDomain
[java] 2015-11-24 09:03:49,645 [ WHE-304] [ ] [ ] ( internal.mgmt.PRRequestorImpl) INFO - RecordWorkInProgress is not enabled
[java] 2015-11-24 09:03:49,851 [ WHE-304] [ ] [ ] (orization.SessionAuthorization) INFO - RSL Update Behavior: Eager
[java] 2015-11-24 09:03:49,951 [ WHE-304] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Bytes input per interaction warning threshold: 50M
[java] 2015-11-24 09:03:49,954 [ WHE-304] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMap using multi-tenant environment: false
[java] 2015-11-24 09:03:49,954 [ WHE-304] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Reading the class group definitions
[java] 2015-11-24 09:03:49,961 [ WHE-304] [ ] [ ] (l.access.ConnectionManagerImpl) ERROR - Not returning connection 0 for database "pegarules" to the pool as it previously encountered the following error
[java] User ID: (unknown)
[java] Last SQL: select pzPVStream from RULESNEW.pr4_base where pxObjClass = ?
[java] java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
[java]
[java] at oracle.jdbc.driver.SQLStateMapping.newSQLException(SQLStateMapping.java:91)
[java] at oracle.jdbc.driver.DatabaseError.newSQLException(DatabaseError.java:112)
[java] at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:173)
