Infosys
Rules Upgrade Failed - 6.2SP2 to 7.1.2 | ORA-00942: table or view does not exist | looking for pr_data table in Rules Schema
We are performing an upgrade from 6.2SP2 to 7.1.2.
During Rules Upgrade build got failed in _upgradeRuleBase step. Please find the error below :
[java] 2017-03-03 05:39:05,327 [ main] [ ] [ ] (l.access.MigrateSQLChangeProxy) INFO - Migrating instances of Rule-Application-Requirement from V7_DEVA_RULES.pr4_rule to V7__DEVA_RULES.pr4_rule_requirement
[java] 2017-03-03 05:39:05,533 [ main] [ ] [ ] (l.access.MigrateSQLChangeProxy) INFO - Migrated 93 instances of Rule-Application-Requirement
[java] 2017-03-03 05:39:05,538 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) ERROR - Not returning connection 0 for database "pegarules" to the pool as it previously encountered the following error
[java] User ID: (unknown)
[java] Last SQL: select count(*) as "count" from V7_DEVA_RULES.pr_data where pxObjClass = 'Data-Project-Task'
[java] java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
[java]
Same kind of issue illustrated in the below link. However this could not help us to resolve the issue.
"setupDatabase.properties file setting bypass.pega.schema is not set to true"
[java]
Please let us know if there are any solution this issue.
