High volume of Pega Alert 0005 on pr_data table
We are getting Pega alert 0005 on pr_data table on high volume.
Sample alert:-
(1) Database operation took more than the threshold of 500 ms: 26,763 ms SQL: SELECT "PZPVSTREAM" AS "pzPVStream", "PZINSKEY" as "pxInsHandle" from PH_WBNLCHPS_DATA_OWNER.pr_data WHERE ( "PZINSKEY" LIKE ? ) AND ( "PXOBJCLASS" = ? ) inserts: <%ING-WORK SRVC00033-210220%> <PegaCommBank-Corr-Swift>
(2) Database operation took more than the threshold of 500 ms: 520 ms SQL: SELECT "PC0"."UTI" AS "UTI" , "PC0"."EXCEPTIONREF" AS "EXCEPTIONREF" , "PC0"."LINKDATE" AS "LINKDATE" , "PC0"."NOTE" AS "NOTE" , "PC0"."OPERATORID" AS "OPERATORID" , "PC0"."SOURCESYSTEM" AS "SOURCESYSTEM" FROM PH_WBNLCHPS_DATA_OWNER.Research_Links "PC0" INNER JOIN PH_WBNLCHPS_DATA_OWNER.pr_data "Test" ON ( ( "PC0"."UTI" = "Test"."PYLABEL" ) AND "Test"."PXOBJCLASS" = ? ) inserts: <Data-Transaction_Test> *
(3) Database operation took more than the threshold of 500 ms: 404,580 ms SQL: SELECT "PZPVSTREAM" AS "pzPVStream" FROM PH_WBNLCHPS_DATA_OWNER.pr_data WHERE ( "SICORRATTACHSTATUS" = ? ) AND ( "PXOBJCLASS" LIKE ? ) inserts: <Not Yet Sent> <PegaCommBank-Corr-%> *
Sample alert:-
Please suggest some solution to resolve this alert.
