PEGA0005 alerts on system tables
Article SA ID: SA-22532 indicates it was written for pega alerts in 7.1.6: https://community.pega.com/support/support-articles/pega0005-alerts-alert-logs
If we are experiencing the same in 7.1.9, and have the following errors:
1) Database update took morethan the threshold of 250 ms: 7,329 ms update xxxx.pr_sys_statusnodes set pyLastPulseDateTime = ? where pzInsKey = ?
2) Database operation took morethan the threshold of 250 ms: 6,607 ms SQL: {call xxxx.sppr_sys_updatescache_gettime (?,?,?)}
Are the same indexes still valid? Or are there new indexes we need to build? The second item above is not mentioned in the original article. Are there separate indexes for that stored procedure?
