Nordea
SE
Last activity: 14 Sep 2020 11:02 EDT
Socket Timeout Exception - StaleConnectionException
We get below error frequently in all our test & production environments:--
here was a problem with the database when getting a list:
com.pega.pegarules.pub.database.ConnectionException: Database-General Connection Exception 17002 08006 IO Error: Socket connect timed out DSRA0010E: SQL State = 08006, Error Code = 17,002
DatabaseException caused by prior exception: com.ibm.websphere.ce.cm.StaleConnectionException: IO Error: Socket connect timed out DSRA0010E: SQL State = 08006, Error Code = 17,002
| SQL Code: 17002 | SQL State: 08006
DatabaseException caused by prior exception: java.sql.SQLRecoverableException: IO Error: Socket connect timed out DSRA0010E: SQL State = 08006, Error Code = 17,002
I understand socket timeout can due to many reasons, application code, networking, service implementation but could you suggest where we shall look first?
As per the suggestion given in the article - https://www.ibm.com/support/pages/websphere-application-server-staleconnectionexception, Is it possible to implement this recommendation: "Write your application code to catch SCE's and retry the connection request x number of retries. This is the preferred method." ?
