Maximus
Last activity: 17 Nov 2020 15:36 EST
Deploy step throws Socket timeout error in deployment manager
Hi Team,
We are currently deploying the changes to higher environment using Deployment manager(4.6) pipeline and Pega version 8.3.1. Recently, we are noticing the Deploy step which pushes the code to Test environment getting failed for first time. In logs, we see the below error.
ERROR Deploy task failed. Reason: Error creating Restoration pointCaught unhandled exception: java.lang.RuntimeException: java.net.SocketTimeoutException: Read timed out
Kindly help us with the resolution. While we trace it, we see pzexecuterestconnector activity step 5 fails with socket timeout error. But we could not see the reason for socket timeout error.
Deepa
This post appears to be a duplicate of your question with the same name that has a reply on it.
I will close this post to future replies. Please continue your conversation on Deploy step throws Socket timeout error in deployment manager
Thank you!
