"Check Rule override" throws Socket timeout error in deployment manager
We are currently using Deployment Manager (version 5.6.2) with a Pega 24.1.3 on-premise setup. We consistently encounter socket timeout exceptions at the step "Check Rule override" when using the merge pipeline to merge our branches, especially when the branch contains a large number of rules. Then the merge process is being blocked. Does someone has also the same issue?
RULE-SERVICE-REST DEVELOPMENTSTANDARDS V1!CHECKRULEOVERRIDES_VAR37CEE1B5235C3404D8800A28A48C4A33 #20210812T105042.346 GMT has exceeded the threshold of 1,000 ms: 179,558 ms;pxServiceInMapReqElapsed=0;pxServiceOutMapReqElapsed=0;pxServiceActivityElapsed=2201;pxParseRuleTimeElapsed=0;
