Smart shape create Pdf
Hi team,
i created a pdf from section with dynamic layout, the section included a paragraph where i set in presentation tab "background-color: white;".
I used for pdf generation "Smart shape create Pdf" , but the pdf genereted present a gray layout ( pdf attached).
Can i replace the gray layout with white layout ?
thank
Marino.
Hi Marino,
It happens because of empty spaces that are left below.
Can you try with additional filler section with certain width and height.
Another way would be to check the markUp that gets generated for the PDF.
You can trace the scenario to get to exact markup and play around with style to understand more on this.
Ujjwal
