Robotics Automation-Logging
Hi there,
We are in the QA testing phase for our robotics solution and encountered a defect in our code. We looked into the logs generated and saw "Stack Trace" generated for the exception. So in order to do diagnostics and by looking at the Logs -Stack Trace, is there any way to identify from logs and trace at which place in the code the bug happened? I am attaching the log file (Stack Trace), if you can help in identifying a keyword in log which can trace/map to code as to which place in code I should be looking in to speed-up diagnostics v/s looking into entire code for the fix. Thanks for your help-Anupam
