Restrict SOAP Service to specific IP range
Hi Team
Customer has a requirement for a SOAP web service on out UAT instance that is exposed to the internet to be restricted to specific IP only
App server Type : Tomcat
Web Server : None
OPEN SR : SR-A88837 and SR-A83796
SETTINGS ATTEMPTED :
The below settings were tried in web.xml but its not working
Hi Team
Web Server : None
though we give the full context, it is restrciting entire /prweb context.
<filter>
<filter-name>Remote Address Filter</filter-name>
<filter-class>org.apache.catalina.filters.RemoteAddrFilter</filter-class>
<init-param>
<param-name>allow</param-name>
<param-value>106\.51\.29\.148|a\.b\.c\.d</param-value>
</init-param>
</filter>
<filter-mapping>
<url-pattern>/prweb/PRSOAPServlet/SOAP/<proprietary information>/Services?WSDL</url-pattern>
</filter-mapping>
<filter>
<init-param>
<param-name>deny</param-name>
<param-value>106\.51\.29\.148|103\.253.\104.\40</param-value>
</init-param>
</filter>
<filter-mapping>
</filter-mapping>
NOTE : - This was successfully implemented in prod and preprod as both env's has a loadbalancer
***Updated by Moderator: Lochan. Removed user added Ask the Expert. Apologies for confusion, shouldn't have been an end-user option; Added SR Exists tag; Updated Categories set; removed proprietary information and URLs***
***Updated by Moderator: Added SR numbers to Related SR section***
A couple of thoughts:
1. Have you checked the tomcat access log that the ip coming in with the right pattern?
2. Can you define a unique filter-name for allow and deny?
