Last activity: 30 Nov 2015 13:59 EST
Checking Apha Numeric ranges with an incoming code
Hi guys,
I have a requirement where it we should check if a code is present in given range. Fortunately, the range happened to be an "AlphaNumeric" for which I am unable to use decision table. I tried using regular expressions but because of large code volumes we considered it as not a best practice.
Example Code: T09.00 to T09.09 (how to check the value in between this range).
Note: I can not write a decision after expanding all those codes beacuse I will end up having more than 300 codes all together.
Please suggest me a best approach to tackle this situation.
Thanks in advance.
Prasan
