Coforge DPA
Last activity: 25 Jun 2019 8:55 EDT
Send Asynchronous soap calls from pega to the service bus
Is it possible to send asynchronous soap calls from pega to the service bus.
Currently the soap calls are synchronous and always expect a reply message (usually a ”confirmBod” message which contains a result code (like an OK).
We prefer that our application would send an async soap call , checks the successful delivery to the service bus based on the http-status (http-200) , and does not wait for a response payload.
I tried this by changing the soap rule with property “Request only” checked. The result is that pega does not wait for a response message.
BUT it does NOT check the http-status. When I disable the endpoint on our service bus. Application did not notice that the delivery was not successful (even with a http-500 internal server error reply-status).
We also noticed there is another way to do asynchronous soap calls in Pega, but you have to setup agents and queues. I think that there is too much impact on the application.
Do anyone knows a more efficient way to do an asynchronous call which also check the http-status, please let me know.
