standard chartered bank
Last activity: 11 May 2017 11:19 EDT
Service SOAP with Custom authentication
Hi Team,
I created a Soap service with Custom Authentication. Let as assume Custom authentication failed ( Ex : User name and password is empty or External validation failed ) . I want to reply back the soap service with custom message( mentioned below ) not like default message comes under <Fault> tag. How set the failure in Authentication activity and how to pass the failure as a service response.
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"><soapenv:Header/>
<soapenv:Body><ErrorData>
<errorId>1010</errorId>
</ErrorData> </soapenv:Body> </soapenv:Envelope>
Christopher
***Updated by moderator: Lochan to add SR details***
***Moderator Edit: Vidyaranjan | Tagged FDBK ID***
Hi Christopher,
We have taken up the suggestion for an enhancement request and I have submitted one on your behalf. You will be able to find the Feedback ID tagged above along with the issue description. To check out the progress of this request, you will need to contact your Account Executive. They will be able to connect and drive it with the team.
Thanks!
