Response not recieved for the Class issue - Pega 7 Upgrade
Hi everybody,
I am currently upgrading few apps from 6.2 SP2 to 7.2.2. I am using installation and upgrade assistant (IUA) to complete the upgrade process. When the IUA executed one of the targets "Optimize Newly Exposed Columns" in the setupDatabase.xml file, it could not proceed further and is waiting for the response from the class "Rule-Obj-Flow" with a job id. I believe it run into trouble while populating the new columns for the class "Rule-Obj-Flow". I let the IUA open for about 6 hours to see if it could progress but in vain. I am keen to know if anyone of you have encountered this issue while doing the upgrade and the fix that you may have implemented.
Any help is very much appreciated!
I have attached both IUA logs and resume.properties file. The message can be found at the end of the IUA logs.txt file. The constant message that is written to the log is below:
[java] 2017-03-19 22:35:08,001 [ pool-1-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Job <BootStrap Commit> Started [Rule-Obj-Property # JobID # 95]
[java] 2017-03-19 22:35:09,001 [ pool-1-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Job <BootStrap Commit> Completed [Rule-Obj-Property # JobID # 95]
[java] 2017-03-19 22:35:09,009 [ pool-1-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Job Completed [Rule-Obj-Property # JobID # 95]
Hi everybody,
From here the message starts popping up continuously, see below -->
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <1799899>
[java] 2017-03-19 23:05:03,388 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <1799899>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <3599797>
[java] 2017-03-19 23:35:03,286 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <3599797>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <5399694>
[java] 2017-03-20 00:05:03,183 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <5399694>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <7199592>
[java] 2017-03-20 00:35:03,081 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <7199592>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <8999490>
[java] 2017-03-20 01:05:02,979 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <8999490>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <10799387>
[java] 2017-03-20 01:35:02,876 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <10799387>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <12599285>
[java] 2017-03-20 02:05:02,774 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <12599285>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <14399183>
[java] 2017-03-20 02:35:02,672 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <14399183>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <16199124>
[java] 2017-03-20 03:05:02,613 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <16199124>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <17999061>
[java] 2017-03-20 03:35:02,550 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <17999061>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <19798957>
[java] 2017-03-20 04:05:02,446 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <19798957>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <21598855>
[java] 2017-03-20 04:35:02,344 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <21598855>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <23398753>
[java] 2017-03-20 05:05:02,242 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <23398753>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <25198621>
[java] 2017-03-20 05:35:02,110 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <25198621>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <26998519>
[java] 2017-03-20 06:05:02,008 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <26998519>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <28798417>
[java] 2017-03-20 06:35:01,906 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <28798417>
[java] Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <30598314>
[java] 2017-03-20 07:05:01,803 [ pool-2-thread-1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Response not recieved for the Class <Rule-Obj-Flow> JobID <86>.Time elapsed (milliseconds) <30598314>
Hi Arun,
After analyzing your shared documents noticed that you are using below driver version,
But the Pega documentation specifies that this version wont be supported and it will cause the problems with Pega 7 internal system date values as shown in attachment.
Reference support document here.
Regards
Mahesh
