S&P
PEGA 722 Upgrade issue - Upgrade from 721
Team - Did anyone faced this issue before while running upgrade wizard?
[java] 2017-02-15 23:50:34,784 (com.pega.pegarules.internal.bootstr) WARNING - Could not initialize data source
[java]
[java] java.lang.IllegalStateException: Unable to initialize JdbcJarReader for table "WORKFLOWRULES722.pr_engineclasses"
Targets:performDeployment
Unable to locate tools.jar. Expected to find it in C:\Program Files\Java\jre1.8.0_101\lib\tools.jar
Buildfile: C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\.\pegaGuiInstallerTemp\build.xml
performDeployment:
SetupProperties:
resumeUpgrade:
upgrade:
startover_or_resume:
Reading Properties from : C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\scripts/setupDatabase.properties
Reading Properties from : C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\scripts/resume.properties
[echo] Resuming upgrade...
[java]
performDeployment:
SetupProperties:
resumeUpgrade:
upgrade:
Initialization:
[echo] Performing Upgrade Finalization
[echo] Using logging configuration from: ./config/deploylogging.properties
[delete] Deleting: C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\scripts\logs\Warnings.log
pega.jdbc.driver.jar=C:\\Users\\siva_sivanarasu\\Documents\\PEGA 7 Folder\\115006_Pega72\\archives\\udf\\ojdbc14.jar
pega.jdbc.driver.class=oracle.jdbc.OracleDriver
pega.jdbc.url=jdbc:Oracle:thin:@//nj12mhf0101-scan.mhf.mhc:1521/pegaqa.world
pega.jdbc.username=WORKFLOWPEGA722_DEPLOYMENT_USR
pega.jdbc.password=*****
pega.rules.schema=WORKFLOWRULES722
pega.data.schema=WORKFLOWDATA722
pega.platform.userids.issecure=
rules.schema.name=WORKFLOWRULES722
data.schema.name=WORKFLOWDATA722
user.temp.dir=
pega.zos.properties=
system.name=pega
production.level=2
multitenant.system=false
update.existing.applications=true
update.applications.schema=true
automatic.resume=true
[echo] *** JVM Arguments -XX:MaxHeapSize=1280m -XX:MaxMetaspaceSize=512m ***
[propertyfile] Updating property file: C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\scripts\resume.properties
Found 53892340KB of free space on 'C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\scripts\${user.temp.dir.root}'
[echo] setting to generated ddl
[echo] Driver Path: C:\\Users\\siva_sivanarasu\\Documents\\PEGA 7 Folder\\115006_Pega72\\archives\\udf\\ojdbc14.jar
[touch] Creating C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\scripts\logs\Warnings.log
[echo] Using C:\Users\SIVA_S~1\AppData\Local\Temp\PegaInstallTemp-15-February-2017-22.55.30 for install scratch space...
[unzip] Expanding: C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\archives\prweb.war into C:\Users\SIVA_S~1\AppData\Local\Temp\PegaInstallTemp-15-February-2017-22.55.30\load
[unzip] Expanding: C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\archives\pegadbinstall-classes.zip into C:\Users\SIVA_S~1\AppData\Local\Temp\PegaInstallTemp-15-February-2017-22.55.30\load
[copy] Copying 1 file to C:\Users\SIVA_S~1\AppData\Local\Temp\PegaInstallTemp-15-February-2017-22.55.30\load\WEB-INF\classes
[delete] Deleting: C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\scripts\taskRuntimes\InitializationRuntime.properties
Checking Configuration Files:
[delete] Deleting: C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\scripts\taskRuntimes\CheckingConfigurationFilesRuntime.properties
[echo] Rules schema has been set to 'WORKFLOWRULES722'
[echo] ***writing resume property upgrade.from.version=07-10-26 to file***
[echo] Upgrading from Pega-RULES product version 07-10-26
Processing Configuration Files:
[delete] Deleting: C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\scripts\taskRuntimes\ProcessingConfigurationFilesRuntime.properties
[propertyfile] Updating property file: C:\Users\SIVA_S~1\AppData\Local\Temp\PegaInstallTemp-15-February-2017-22.55.30\prbootstrap.properties
Configuration:
[delete] Deleting: C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\scripts\taskRuntimes\ConfigurationRuntime.properties
[echo] Database Type: oracledate
[echo] JDBC Driver JAR: C:\\Users\\siva_sivanarasu\\Documents\\PEGA 7 Folder\\115006_Pega72\\archives\\udf\\ojdbc14.jar
[echo] Bootstrap Config: C:\Users\SIVA_S~1\AppData\Local\Temp\PegaInstallTemp-15-February-2017-22.55.30/prbootstrap.properties
[echo] PegaRULES Config: C:\Users\SIVA_S~1\AppData\Local\Temp\PegaInstallTemp-15-February-2017-22.55.30/prconfig.xml
[echo] PegaRULES Logging Config: C:\Users\SIVA_S~1\AppData\Local\Temp\PegaInstallTemp-15-February-2017-22.55.30/prlogging.xml
[echo] Deployment Logging Config: ./config/deploylogging.properties
Generate Upgrade DDL:
Schema Upgrade:
[echo] Skipping automatic schema upgrade because bypass.pega.schema is set to true
Apply UDFs:
Engine Load:
Engine Load Inner:
[delete] Deleting: C:\Users\siva_sivanarasu\Documents\PEGA722\115290_Pega722\scripts\taskRuntimes\EngineLoadRuntime.properties
[java] 2017-02-15 23:50:34,737 (com.pega.pegarules.internal.bootstr) 1050 - Loading bootstrap properties from file:///C:\Users\SIVA_S~1\AppData\Local\Temp\PegaInstallTemp-15-February-2017-22.55.30/prbootstrap.properties
[java] 2017-02-15 23:50:34,752 (com.pega.pegarules.internal.bootstr) INFO - Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
[java] 2017-02-15 23:50:34,755 (com.pega.pegarules.internal.bootstr) INFO - Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
[java] 2017-02-15 23:50:34,756 (com.pega.pegarules.internal.bootstr) 1050 - Unable to locate archive.properties properties, setting warVersion to -1
[java] 2017-02-15 23:50:34,757 (com.pega.pegarules.internal.bootstr) 1050 - Engine schema defined in allclasses: null
[java] 2017-02-15 23:50:34,758 (com.pega.pegarules.internal.bootstr) INFO - Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
[java] 2017-02-15 23:50:34,759 (com.pega.pegarules.internal.bootstr) INFO - Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
[java] 2017-02-15 23:50:34,760 (com.pega.pegarules.internal.bootstr) 1050 - Engine classes schema: null
[java] 2017-02-15 23:50:34,761 (com.pega.pegarules.internal.bootstr) 1050 - Assembled classes schema: null
[java]
[java] at com.pega.pegarules.internal.bootstrap.phase2.jdbc.PegaJdbcURLHandler.<init>(PegaJdbcURLHandler.java:133)Warn - VersionedJdbcJarReader - unable to load classes from the database: Cannot create JDBC driver of class 'oracle.jdbc.OracleDriver' for connect URL 'jdbc:Oracle:thin:@//nj12mhf0101-scan.mhf.mhc:1521/pegaqa.world'
[java] at com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderDataSourceImpl.<init>(JarLoaderDataSourceImpl.java:89)
[java] at com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool.initDBConnection(JarLoaderTool.java:1814)
[java] at com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool.mainImpl(JarLoaderTool.java:1359)
[java]
[java] at com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool.main(JarLoaderTool.java:1115)
***Updated by moderator: Lochan to move post from PSC to Pega 7 Upgrade Center***
