Optum
Last activity: 3 Dec 2019 14:23 EST
Required field validation need not be fired on backwards flow navigation
Hi Pega Experts,
We have the requirement to navigate back from a Tabbed screenflow without checking the mandatory fields validation on the UI screen using Pega V722. For that, we did a small research and we got the below PDN article to resolve this issue.
After we check the function from the above post, we noticed that this function is being called from a FINAL rule:Navigation (HTML Fragment) under RSV=>Pega-EndUserUI:07-10-23. We have done a private edit on this to add the above mentioned function changes directly and we were successful in resolving the issue. But we are afraid of making this FINAL rule changes in our RSV to proceed further. We would like to know Pega confirmation on whether we can bring this function change in our RSV or can we get a Pega fix (HFix/Sol) in the mentioned RSV above? Also, we don't want to get any new issues after making the code changes based on this final rule across the application. I forgot to mention that we have the same application running on the mobile native app and we don't want to get any impact on the mobile side after incorporating the changes mentioned above. Please advise and we are creating an SR on this to get Pega direction on this particular requirement.
Ravi Kumar Pisupati.
Hi Pega Experts,
