TCS
Last activity: 9 Apr 2019 23:11 EDT
PRPC and JIRA Integration
Is it possible to integrate PRPC 7.3.1 personal edition and JIRA (Jira Cloud trial version)?
If yes, Could anyone please let me know how I will get the rest api through which I can connect PRPC and JIRA ? I am struggling to get api. I tried using the below api. But it failed to connect.
Could you please elaborate steps?
Yes you can integrate with JIRA in 7.3.1.
Is your jira cloud instance accessed using "https://jira.atlassian.com/" , then set the jira api url as below. or jira is hosted on a different url then use that instead of the bold text below.
Set the jira api url as ,"https://jira.atlassian.com/rest/api"
Refer to this article for detailed steps: https://docs-previous.pega.com/integrating-agile-workbench-jira-pega-platform-73x-82x
HCL
Is this issue solved?
I am also same error with JIRA cloud URL.
PH
How did you resolve the API URL issue? We are having the same problem
Accenture
Hi , i'm also getting the same error . " Invalid Jira URL "
Accenture
can any one give me suggestions regarding this.
Thomas Sasnett
Accenture
i'm integrating agile work bench to JIRA. it is asking JIRA URL .
I gave " https://XXX.XXX.local/rest/api " and connect . Getting error " Enter Vaild Jira URL"
Please review the content provided in the reply that was marked as the Correct Answer.
If you are still having difficulty after reviewing that, please create a new post as this one has been resolved. This will notify the Community that you need assistance.
Thank you!
Thomas Sasnett
