Pega Systems
Last activity: 14 Feb 2017 20:48 EST
Property optimization wizard issues
After the property optimization wizard is run, data is not getting populated into the newly created column in the database table.
what to check for or fix this..?
***Updated by Moderator: Marissa to add SR Details to post***
What version of Pega are you running?
Pega Systems
Hi Celeste_D
We have 7.2.1 in use.
Hello!
I believe this could be a duplicate question. Do you think this question can be carried over this other question by you? The solution could be similar... Optimization wizard issues
Lochan | Community Moderator | Pegasystems Inc.
Pega Systems
Its not a duplicate item.
There is an issue with the classmap not getting updated correctly which will lead to a property not being populated in exposed column after it is optimized.
In Pega 7.2.1 you want HFix-30080. Open up an SR to request this hot fix.
Pega Systems
Thank you for bringing this up here. it helps!!
Hello!
Do let us know the SR number if you decide to log one for this. We will update this thread to link the 2 effectively.
Refer Raising Support Requests for Hotfixes now made easy! if require the specific steps on how to raise an SR for an existent HFix.
Pega Systems
We used above hotfix.
Thanks JVV_Sharma,
Do you mind replying with the SR # that you opened to obtain above hotfix so that we may track?
Hello!
On reviewing the SR, we see that it has been resolved. HFix-30080 was provided as a result. Please raise an SR if you need the same HFix. Refer: Raising Support Requests for Hotfixes now made easy!
Thank you!
