Accenture
Last activity: 24 Jul 2019 10:01 EDT
Issue in Creating Rest Integration Wizard
I was trying to create a Rest Service with Rest Integration Wizard and it took long as an hour. And none of the rules were created and I found the error log as attached.
Kindly help me advise me.
Thanks and Best Regards,
Aung
***Edited by Moderator: Lochan to update SR***
Accenture
Hi Lochan,
Actually, the property is already created in the upper layer like the Organization layer which is shared across different applications. When starting creating the Rest Service, the wizard may do the validation for creating the property inside the child class the same name as Parent one. Then it hanged the wizard. After changing the property from either web service or in the organization layer resolved the problem.
Aung
I see NullPointerException in the log, what is the Pega platform version? Is this consistently reproducible? Has this worked before?
Updated: 10 Jul 2019 8:04 EDT
Accenture
I am using 7.4 version.
If this is consistently reproducible, go ahead and open a ticket with Pega GCS.
Accenture
Hi KevinZheng_GCS,
It could be reproducible, could you please guide me how should I go ahead with Pega GCS.
I am from Accenture Singapore.
Aung
Hello Aung,
You can create a Support Request here: https://msp.pega.com
If this is your first one, please make sure you are affliated to your organization's account. You can find more details here: https://community.pega.com/knowledgebase/working-pega-support
Let us know if this helps.
Accenture
Hi Lochan,
I could raise ticket for this issue and you may close this thread already.
Aung
Chandra Baipalli Salaimathimamani Gurusamy Yesuraju Chokka Laveesh Toshniwal Santhosh Konkamurthy and 4 More
Hi Aung,
Thank you! We would prefer to keep this post open so that we can track the SR and update the resolution back here. This way it will help other community members too! Please let us know the SR number once you have the chance to create it.
Accenture
Hi Lochan,
This is a SR-D29358 that I opened for it.
Aung
Thank you Aung,
I reviewed the SR see that the issue was the property created by the Rest Integration Wizard was existing in the environment. Changing the name of the existing property solves the issue.
I will now mark this post as Answered.
Kuba Paluch
Accenture
Hi Lochan,
Aung
Hi Aung,
Thank you for adding this information! It helps!
