de Volksbank
Last activity: 21 Oct 2016 23:54 EDT
Property Optimize for reporting
Hi.. We are using Pega V7.2 and we did Optimize for reporting on one property in dev. Now I have below doubts on this. 1) How we will migrate this schema change to Higher environments? adding Data-Admin-DB-Table instance of the class group in jar file will serve the purpose or anything else required? 2)After migrating to higher environment, will pega automatically pull the data for that exposed column from BLOB for the instances already present in DB? or we need to run any column population job?
