Property on clipboard can't be referenced when DBMS is PostgreSQL
I am using RDB-List method to load data from table but I can't reference data in the activity because in Pega, properties are defined in combination of upper case and lower case while on clipboard properties are loaded by all lower case.
- Activity (I am trying to log "pzInsKey" but it doesn't work)
- Connect SQL
- Clipboard (Note it is loaded as "pzinskey", not "pzInsKey".. this is why Log-Message does not work)
If I try to access "pzinskey" instead of "pzInsKey" in the activity, it doesn't even let me save the rule. System only recognizes "pzInsKey" as it is defined as such in PRPC.
- Connect SQL
According to https://collaborate.pega.com/question/upper-case-and-lower-case-issue-postgresql-database, I updated External Mapping to map PRPC property name (upper case / lower case) and PostgreSQL column name (lower case) as below but the result was the same. How can I resolve this issue?
