Problem while installing Pega 7.2.2
Hi all,
We are trying to install Pega 7.2.2 in Cloud Foundry. Unfortunately, nothing's happening after this message:
Hi all,
Engine Load Inner:
[java] 2017-06-12 12:50:35,017 (com.pega.pegarules.internal.bootstr) 1050 - Loading bootstrap properties from file:////var/folders/h3/kk34gsjd1h5_j1ptqpqgx46w0000gn/T//PegaInstallTemp-12-June-2017-12.48.38/prbootstrap.properties
[java] 2017-06-12 12:50:35,031 (com.pega.pegarules.internal.bootstr) INFO - Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
[java] 2017-06-12 12:50:35,033 (com.pega.pegarules.internal.bootstr) INFO - Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
[java] 2017-06-12 12:50:35,034 (com.pega.pegarules.internal.bootstr) 1050 - Unable to locate archive.properties properties, setting warVersion to -1
[java] 2017-06-12 12:50:35,034 (com.pega.pegarules.internal.bootstr) 1050 - Engine schema defined in allclasses: null
[java] 2017-06-12 12:50:35,035 (com.pega.pegarules.internal.bootstr) INFO - Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
[java] 2017-06-12 12:50:35,035 (com.pega.pegarules.internal.bootstr) INFO - Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
[java] 2017-06-12 12:50:35,036 (com.pega.pegarules.internal.bootstr) 1050 - Engine classes schema: null
[java] 2017-06-12 12:50:35,036 (com.pega.pegarules.internal.bootstr) 1050 - Assembled classes schema: null
Anybody has any clue?
