BitsInGlass
BitsInGlass
BitsInGlass
Posted: Jan 19, 2018
Last activity: Jul 3, 2018
Last activity: 3 Jul 2018 13:48 EDT
Pega personal edition 7.2.2 installation error
Hai all
I am getting this following error while installing pega personal edition in my laptop.
OS is windows 7.
kindly help me n this regard
BUILD FAILED
C:\PEGA\115291_P722-PE\pegaGuiInstallerTemp\build.xml:285: exec returned: 1
Total time: 43 minutes 36 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:90)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:87)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:80)
... 2 more
--- Nested Exception ---
Hi Ramprasad,
Thanks for posting on PSC.
I could see the exception only, please provide the application server starting logs to analyze the stack leading to the exception.
On my research on PDN, I could find similar issue reported with JDK path access.
Please verify,
- Is your application is having correct access to JDK path?
Local Change:
Rectify the systems environment variable such that it points to JDK 1.7 or 1.8 correctly. Also, use GUI installation assistant.
Hope it helps, kindly notify by marking this post as answered/helpful if it does.
Asif
