Problem after update from Pega 7.2.2 to 7.3
Hello everybody,
I have installed the Pega 7.2.2 software on a windows server 2012 R2 virtual machine.
I have installed in the same machina the database Postress ( Proprietary information hidden x64) and the application server Apache tomcat (8.5.11) with java 8.121 (jre and sdk).
The installation of Pega 7.2.2 is gone all fine.
I'm try to update to Pega 7.3 with the update package and setup is gone all fine.
When When I have try to restart the application server, it crash with this exception:
2017-08-24 12:48:58,553 [ PEGADEV] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver version: PostgreSQL 9.4.1212.jre6
2017-08-24 12:48:58,553 [ PEGADEV] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Version of JDBC supported by driver: 4.0
2017-08-24 12:49:08,116 [ PEGADEV] [ ] [ ] [ ] ( internal.access.Opener) ERROR - ***** Caught exception during open
com.pega.pegarules.pub.database.DatabaseException: Database-General There was a problem opening a database instance RULE-APPLICATION PEGARULES 07.10 0 42501 ERRORE: permesso negato per la relazione pr4_rule_application
DatabaseException caused by prior exception: org.postgresql.util.PSQLException: ERROR: access deny for relation pr4_rule_application
| SQL Code: 0 | SQL State: 42501
Hello everybody,
at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:262) ~[prprivate.jar:?]
at com.pega.pegarules.data.internal.store.AutoCommitTransaction.performQuery(AutoCommitTransaction.java:387) ~[prprivate.jar:?]
at com.pega.pegarules.data.internal.access.Opener$1.getResultPageFromDatabase(Opener.java:731) ~[prprivate.jar:?]
I have check also the datebase log for more information and i find this:
2017-08-24 12:49:09 CEST ERROR: access deny for relation pr4_rule_application
2017-08-24 12:49:09 CEST ISTRUZIONE: select pzPVStream , pxCommitDateTime from pega_rules.pr4_rule_application where pzInsKey = $1
Someone can help me?
I have solved the problem. The basic databese user after upgrading don't have full select rights.
So, after run these following query all works fine.
GRANT SELECT ON ALL TABLES IN SCHEMA pega_data TO pega_basic;
GRANT SELECT ON ALL TABLES IN SCHEMA pega_rules TO pega_basic;
GRANT EXECUTE ON ALL FUNCTIONS IN SCHEMA pega_data TO pega_basic;
GRANT EXECUTE ON ALL FUNCTIONS IN SCHEMA pega_rules TO pega_basic;
Thanks.
