On-premise '23 Pega platform does not start with Tomcat
After installed '23 successfully, we failed to start Pega as Stream node.
Also we failed to start WebUser node.
I already looked through this Configuring an embedded stream service
There are some messages in PegaRULE.log related to failing to start, below.
2023-11-08 08:47:32,602 [ALIZE_STREAM_SERVICE] [ STANDARD] [ ] [ ] (prpc.service.ServiceDefinition) ERROR - Unable to create DSM service DATA-DECISION-SERVICE-STREAMSERVER DEFAULT
java.lang.reflect.InvocationTargetException: null
2023-11-08 08:47:32,754 [eue301z.dev.jp.local] [ STANDARD] [ ] [ ] (.internal.GenericErrorAnalyzer) ERROR - Health monitor received critical error notification from:
com.pega.pegarules.pub.context.InitializationFailedError: PRNodeImpl init failed
Caused by: com.pega.pegarules.pub.PRRuntimeException: Startup Task: [INITIALIZE_STREAM_SERVICE] has failed after retries or with error
Caused by: com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
Caused by: java.lang.reflect.InvocationTargetException
Caused by: com.pega.platform.stream.StreamServiceException: Failed to configure StreamAPI provider
Caused by: com.pega.platform.stream.StreamServiceException: 'services/stream/broker/url' isn't provided.
2023-11-08 10:25:23,298 [gaRULES-ShutDownTask] [ STANDARD] [ ] [ ] ( etier.impl.EngineStartup) ERROR - Failed to execute task:class com.pega.pegarules.session.internal.engineinterface.shutdown.shutdowntasks.StopIndexingTask
java.lang.IllegalStateException: Calling a method from NodeLifecycle, before initializing it!
Why do we fail like this ?
we want to use embedded kafka because we can't provision external kafka.
Is there any configuration for stream node ?
***Edited by Moderator Marije to add Support Case ID**
