sirar by stc
SA
Last activity: 30 Jan 2024 10:51 EST
Background node does not start on On-premise Pega '23
Hi Everyone
After installed '23 successfully, we failed to start Pega as Stream node.I successfully addressed a Stream node issue by adding <env name="services/stream/provider" value="Internal"/> to prconfig.xml . Stream node is running.
However still are facing another issue on Search and BackgroundProcessing nodes. "Failed to initialize StreamAPI: attempt 1 from 6. Next retry in 20 seconds java.util.concurrent.TimeoutException: null"
There is no external service for Kafka and Elasticsearh. Also was no connection details for timeout issue ( source & target ip , port) in logs after changing log levels for cluster and stream class.
Troubleshooting Steps Already Taken:
- Checked server connectivity and network configurations.
- On-premise '23 Pega platform does not start with Tomcat | Support Center applied to prconfig.xml
- Verified the configurations related to Stream services in Pega.
- Reviewed relevant Pega documentation for potential solutions.
Is there any configuration for internal stream conf ? What are the common causes for a TimeoutException during StreamAPI initialization on Search and BackgroundProcessing nodes?
************************* Logs ***********************************************
Hi Everyone
(.stream.StreamServiceValidator) ERROR - Failed to initialize StreamAPI: attempt 1 from 6. Next retry in 20 seconds
at java.util.concurrent.CompletableFuture.timedGet(CompletableFuture.java:1888) ~[?:?]
at java.util.concurrent.CompletableFuture.get(CompletableFuture.java:2023) ~[?:?]
at com.pega.platform.stream.StreamServiceValidator.ping(StreamServiceValidator.java:91) ~[stream.jar:?]
at com.pega.platform.stream.StreamServiceValidator.validate(StreamServiceValidator.java:69) ~[stream.jar:?]
at com.pega.platform.stream.StreamService.getStreamAPI(StreamService.java:74) ~[stream.jar:?]
at com.pega.platform.modules.internal.guice.StreamServiceModule.createStreamAPI(StreamServiceModule.java:58) ~[modules-bridge.jar:?]
at com.google.inject.internal.ProviderInternalFactory.provision(ProviderInternalFactory.java:81) ~[guice-4.0.jar:?]
at com.google.inject.internal.InternalFactoryToInitializableAdapter.provision(InternalFactoryToInitializableAdapter.java:53) ~[guice-4.0.jar:?]
at com.google.inject.internal.ProviderInternalFactory.circularGet(ProviderInternalFactory.java:61) ~[guice-4.0.jar:?]
at com.google.inject.internal.InternalFactoryToInitializableAdapter.get(InternalFactoryToInitializableAdapter.java:45) ~[guice-4.0.jar:?]
at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46) ~[guice-4.0.jar:?]
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1103) ~[guice-4.0.jar:?]
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40) ~[guice-4.0.jar:?]
at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:145) ~[guice-4.0.jar:?]
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:41) ~[guice-4.0.jar:?]
at com.google.inject.internal.InjectorImpl$2$1.call(InjectorImpl.java:1016) ~[guice-4.0.jar:?]
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1092) ~[guice-4.0.jar:?]
at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1012) ~[guice-4.0.jar:?]
at com.google.inject.internal.InjectorImpl.getInstance(InjectorImpl.java:1051) ~[guice-4.0.jar:?]
at com.pega.platform.modules.internal.ModulesBridgeImpl.getStreamAPI(ModulesBridgeImpl.java:661) ~[modules-bridge.jar:?]
at com.pega.dsm.dnode.api.server.StreamServerService.getStreamAPI(StreamServerService.java:232) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.validateStreamAPI(StreamServiceInitializationTask.java:95) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.access$100(StreamServiceInitializationTask.java:32) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask$1.run(StreamServiceInitializationTask.java:82) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask$1.run(StreamServiceInitializationTask.java:77) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:77) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper$2.run(ServiceHelper.java:295) ~[d-node.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1381) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1124) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:931) ~[prprivate-session.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContextInternal(ServiceHelper.java:288) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContext(ServiceHelper.java:150) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.initStreamServerServiceAndValidate(StreamServiceInitializationTask.java:77) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.server.StreamServiceInitializationTask.runTask(StreamServiceInitializationTask.java:51) ~[d-node.jar:?]
at com.pega.pegarules.session.internal.async.startup.StartupTask$1.run(StartupTask.java:55) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:897) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.async.startup.StartupTask.run(StartupTask.java:48) ~[prprivate-session.jar:?]
at java.lang.Thread.run(Thread.java:834) ~[?:?]
2023-12-28 15:25:55,508 [ALIZE_STREAM_SERVICE] [ STANDARD] [ ] [ ] (.stream.StreamServiceValidator) ERROR - Failed to initialize StreamAPI: attempt 2 from 6. Next retry in 20 seconds
2023-12-28 15:26:20,510 [ALIZE_STREAM_SERVICE] [ STANDARD] [ ] [ ] (.stream.StreamServiceValidator) ERROR - Failed to initialize StreamAPI: attempt 3 from 6. Next retry in 20 seconds
2023-12-28 15:26:30,246 [rver.Default-Pulse:2] [ STANDARD] [ ] [ ] (api.server.StreamServerService) DEBUG - Finished executing stream service pulse operation
2023-12-28 15:26:45,512 [ALIZE_STREAM_SERVICE] [ STANDARD] [ ] [ ] (.stream.StreamServiceValidator) ERROR - Failed to initialize StreamAPI: attempt 4 from 6. Next retry in 20 seconds
2023-12-28 15:27:10,514 [ALIZE_STREAM_SERVICE] [ STANDARD] [ ] [ ] (.stream.StreamServiceValidator) ERROR - Failed to initialize StreamAPI: attempt 5 from 6. Next retry in 20 seconds
2023-12-28 15:27:30,324 [rver.Default-Pulse:2] [ STANDARD] [ ] [ ] (api.server.StreamServerService) DEBUG - Finished executing stream service pulse operation
2023-12-28 15:27:35,515 [ALIZE_STREAM_SERVICE] [ STANDARD] [ ] [ ] (.stream.StreamServiceValidator) ERROR - Failed to initialize StreamAPI: attempt 6 from 6
2023-12-28 15:27:35,530 [ALIZE_STREAM_SERVICE] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) ERROR - Error in the execution of Startup Task: [com.pega.dsm.dnode.api.server.StreamServiceInitializationTask]
com.google.inject.ProvisionException: Unable to provision, see the following errors:
1) Error in custom provider, com.pega.platform.stream.StreamServiceException: Failed to initialize StreamAPI. Can not connect to the stream provider.
at com.pega.platform.modules.internal.guice.StreamServiceModule.configure(StreamServiceModule.java:53)
while locating com.pega.fnx.stream.api.StreamAPI
1 error
at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1025) ~[guice-4.0.jar:?]
Caused by: com.pega.platform.stream.StreamServiceException: Failed to initialize StreamAPI. Can not connect to the stream provider.
at com.pega.platform.stream.StreamService.getStreamAPI(StreamService.java:86) ~[stream.jar:?]
... 23 more
Caused by: java.util.concurrent.TimeoutException
... 23 more
2023-12-28 15:27:35,531 [] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - All registered 'StartupTasks' (parallel cache loading) have finished.
2023-12-28 15:27:35,532 [] [ STANDARD] [ ] [ ] ( internal.mgmt.PREnvironment) ERROR - com.pega.pegarules.pub.PRRuntimeException: Startup Task: [INITIALIZE_STREAM_SERVICE] has failed after retries or with error
Thank you in advance for any suggestions, advice, or shared experiences related to this issue.
***Edited by Moderator Marije to add Support Case Details INC-B417***
