Lyance
TN
Last activity: 22 Jul 2016 14:06 EDT
Perform an action from a button in harness "Review"
How to call a flow action from a button in the harness "Review"?
Lyance
TN
Actually, it worked. I used the run script action and the "handleMenuAction" as function. It used as input parameters :
- actiontype: "DisplayAction"
- prevTaskIndex: "script:1"
- event: "script:event"
- taskIndex: "script:1"
- actionName: flowActionName
- insHandle: for this parameter i used the pyFlowKey in pyFlowActionsList for this flow action
Hello
You can check how the navigation ( menu ) works for Action button in pyCaseHeader section.
Based on that you can try design your button.
Lyance
TN
I followed the standard button "Edit" but when i click on this butto, it shows the section of the flow action and when i submit nothing changes (the status is still the same and it doesn't pass to the next flow)
You may use 'Launch -> Local action' on button and show your flowaction in modal dialog or an overlay.
Lyance
TN
I tried that, it doesn't work
Hi Mariam
could you elaborate on the use case. If you are "performing" a flow action, that would mean that you are moving your case ahead in the flow. should you not be in "Perform" harness ? Why do you need to be in review harness ?
Lyance
TN
It's a specification from the client, he wants to seperate this action in a button near the actions button. So, it is located in the harness "Review".
Lyance
TN
Blue Shield of California
Updated: 29 Jun 2016 3:33 EDT
Lyance
TN
Hello Nixon,
Try to investigate those parameters by opening the Tracer then opening the actions list. You will find a page "pyFlowActionLis" in the tracer which contains all actions. Try to open the action that you want to perform it as a button "Update Progress", you will find something like that:
I opened for example the "assignCase" action to show you the details, you need to insert those parameters:
For the first parameter "pyFlowKey", it cotains the pzInsKey so i created a new property "AssignFlowKey" to save this value and I added a declare expression for it like that:
Hello Nixon,
After that, you need to use this property as parameter for the Run Script function. That's all.
Thank you so much Mariem for your solution. This was a huge blocker in my project which has now been cleared.
Cheers!
PSC
While trying to implement this, I get an error "Required parameter assignmentHandle". If I copy pyFlowKey from the tracer, it works. I get the error when I try to use the property pzInsKey and set the parameter through the declare expression.
