BlueRose Technologies
Last activity: 22 Aug 2019 13:22 EDT
How to perform an local action in Review Harness ?
A property named "Comment" is present in a case. i.e. Comment is shown under Case Details layout in Review Harness. Now I want to add/update value of comment from this review harness without performing it from case wide local actions.
I tried keeping a button in the Case Details tab of the case which is inside the review harness. On click of this button, it tried action set ---Click---Launch Local Action in the form of modal dialog. I created a flow action with indicator selected as "Local Action" and a section to allow user to enter or update the comment -- single text box.
Now when i click the button, modal dialog pops up and flow action's associated section is shown.On click of submit from the modal dialog...the existing assignments are hidden and an error message is shown in the review harness where the assignments were shown in the review harness with begin button prior to click of this button.
Error Message: You are not authorized to perform.
PFA the screenshots of the same.
Why this error happens?
If I follow this approach, do I need to handle case locking on the post processing of the flow action?
Can't we perform on actions from Review Harness?
I don't think you can apply updates from a review harness unless you switch to perform harness in between.
If you try to update anything on your case a lock will be requested unless you changed the locking mechanism.
