PegaRULES Web Application Error Message: An has occurred processing this request.
I have used a Decimal property(.Amount) and to this onchange action i have kept refresh section inside this i have used a activity ans called validate rule to display some custom validation message like entered amount should be >1 if Amount less than 1 etc.....
But when I'm entering a alpha numeric value(say: 123a)........section is showing
then after this is getting failed with Pega exception.
Could you please help on this.
UI Error:
PegaRULES Web Application Error Message: An has occurred processing this request. Please contact your system administrator. PegaRULES 7.10 ML7 (coreAssemblyCached_717_644)
Can you just avoid that by allowing only numeric?
