PegaMarketingNBAA_FW_PreReqs & PegaMarketingNBAA_FW Application in the Pega Marketing
The below application rules are deprecated/modified in Pega Marketing framework/product (referring to Pega marketing for communications).
- PegaMarketingNBAA_FW_PreReqs
Could you please let me know in which version of the Pega Marketing this application rules/build on application rules are deprecated/modified?
Is there any reference/details which provide more details on the deprecated application rules and Ruleset?
As part of tradition upgrades, what could be impact due to change in the build on application rules ?
Due to depreciated/modified application rules, did anyone faced any issues with this scenarios while doing migration or upgrade of the Pega Marketing product/framework on different version of Pega product?
Any Suggestions?
Thanks in advance.
Regards
SVAQuest
Hi Prasanth,
Thanks for the quick response.
It is related to Pega Marketing for Communications v7.31 and Pega v7.3.1.
In this scenario, it will a huge impact when we do upgrade and perform “as-is” migration from lower environment into Pega v7.3.1.
Since build on application is decoupled (including change in inheritance with the depreciated NBAA Ruleset) for Pega Marketing for Communications v7.31.
It will require more efforts for changing rules and to sync with design and existing flow when we continue with additional enhancements in the lower environments.
If my assumption is correct, the previous post are related to Pega v7.4
Regard
SVAQuest
