Amazon
Last activity: 7 Aug 2023 10:33 EDT
Pega upgrade from 7x to 8x - prpcutils
We are currently on Pega 7x version and using prpcutils for code deployment.
We will soon be upgrading to 8x version.
Pega documentation doesn't mention anything about updating the prpcutils. We'll update the prpcutils to correct version, but in the meantime, can Pega 7x prpcutils be used for deploying code to Pega 8x?
@shrikantbp When you upgrade to Pega 8x, you should be able to use the prpcutils for the same to deploy the code. What is the use case of using the Pega 7 prpc utils to import the code in Pega 8?
