Pega Scenario Testing failed on blank text field
I am performing Pega scenario test with the case type. When I create a scenario test , wizard recording starts then I entered all the field value in it and saved the test case.
When I ran the scenario test 3-4 text field it remains blank and eventually test result is getting failed.
I am expecting solution on this.
Thank you.
***Edited by Moderator Marije to change Content Type from Discussion to Question; added capability tags***
@ChetanB4385 what is the log file error showing?
Did you already go through other forum content such as Creating a scenario test, UI-based tests with automated scenario testing, Scenario testing: How to create, run & Edit test cases , Pega Test Automation Kit, Pega Scenario Testing, Limitations of Pega Scenario testing, Pega Scenario Testing FAQs,
@NAQUS @nayam @vadlp @MadhuriVasa is this something you could help with?
