How to run pega scenario test suites from pega deployment manager
I try to run pega scenario test suites from pega deployment manager, but it shows the error like
"Unable to open an instance using the given inputs: pxObjClass = \"Rule-Test-Suite\", pyClassName = \"RULE-TEST-SUITE\", pyPurpose = \"TS_PORTALSAMPLETEST\"",
Does pega deployment manger support to run scenario test suites?
== Detail ==
I create a scenario test suite which inskey is "RULE-TEST-SUITE!TS_PORTALSAMPLETEST",
And the detail configurations are following
<pxObjClass>Rule-Test-Functional-Suite</pxObjClass>
<pyClassName>Rule-Test-Suite</pyClassName>
<pyPurpose>TS_PortalSampleTest</pyPurpose>
Then I add a "Run Pega unit tests" job in deployment manager and try to call that scenario test suite.
But it seems that job only support to run which class is "Rule-Test-Suite", not the scenatio test caeses.
Do you have any other solution to run scenario test cases from deployment manager?
Cheers!
