Running PegaUnit Test suites with the Execute Tests service in Pega 7.4 clarification
I am following this article: https://community.pega.com/knowledgebase/articles/running-pegaunit-test-cases-and-test-suites-execute-tests-service-pega-74
My question is, in the article, it says LocationOfResults parameter. Can anyone explain me more about this.
Since it says that LocationOfResults is an optional parameter, so I didn't use it while configuring the job in Output response to file field.
In post build actions, when I enter **/*.xml in Test Report XML field, it gives an error '**/*.xml' doesn't match anything: '**' exist but not '**/*.xml'.
The job is failing at Post Build Actions.
Response Code: HTTP/1.1 200 Success code from [100‥399] Recording test results ERROR: Step ‘Publish JUnit test result report’ failed: No test report files were found. Configuration error? [Office365connector] No webhooks to notify Finished: FAILURE
Also, the parameter, RunWithCoverage is set false by default. To make it true, should I pass it in the URL of HTTP request or is there a different way for it.
TIA!
