SberTech
RU
Last activity: 24 Jul 2019 23:14 EDT
Pega nodes are not seen in cluster management
Hello. I've got pega cluster with 5 separated nodes and 4 nodes of it are not visible in "Cluster management" tab but they exist in "System Node" tab. If i manually set in prconfig options:
<env name="identification/cluster/protocol" value="Hazelcast" />
<env name="cluster/Hazelcast/interface" value="IP address of this node" />
<env name="cluster/Hazelcast/ports" value="port range" />
<env name="cluster/Hazelcast/members" value="members IP of the clusters" />
<env name="indexing/distributed/network/host" value="IP address of this node" />
for each of them my problem dissapear and all nodes become visible. What should i check/do to solve this problem without editing prconfig ?
Without manual configuration all of nodes are using Proprietary information hidden ip-adress.
JPMorgan Chase & Company
Have you tried clearing the entries in pr_sys_statusnodes and start nodes one by one.
SberTech
RU
Hello. Tried. It didn't help.
Virtusa Ltd
I am new to PEGA. I can see the same issue. I don't see all nodes in cluter management and I have cleared the statusnodes tables. How to configure through DSS. Could you please help me out?
thanks
Hi, Do you have multiple IPs assigned to your servers?
Virtusa Ltd
I see some of the servers IP changed. How to clear those entries?
SberTech
RU
Hey. Just add on each node in procnfig file this line, replacing with your ip-adresses: <env name="cluster/Hazelcast/members" value=" Proprietary information hidden, Proprietary information hidden, Proprietary information hidden, Proprietary information hidden, Proprietary information hidden" />
Lakshmi Swathi Chinni
Virtusa Ltd
One of my environment using ignite. 3 node ignite cluster.
In Ingite Server - prconfig.xml (prcluster_service.war)
<env name="identification/cluster/protocol" value="ignite" />
<env name="identification/cluster/public/address" value="XXXX-ignite server IP" />
And on Pega Node:
- Added below lines to prcofig.xml (prweb/web-inf/classes) to enable to client mode.
<env name="cluster/clientserver/clientmode" value="true" />
- Restarted the Tomcat
--- My Question is - As I have 3 Ignite Servers, Can I mention three Node IPs like below for prconfig.xml (prcluster_service)
Will below entry work for Ignite also?
Ex : <env name="cluster/ignite/members" value=" Proprietary information hidden, Proprietary information hidden, Proprietary information hidden, Proprietary information hidden, Proprietary information hidden" />
SberTech
RU
Hey. It should work.
Mariane Ammar Elie Rahal
Infosys
Please try to restart the node and that should work.
