Orange Business Services
Last activity: 15 Nov 2018 3:35 EST
Cluster Nodes Visibility in Cluster Management Tab.
Hi Team,
We are using a Load balancer in production and we have two different server nodes to use for load balancing. at LB side, we can see two nodes are visible. But in Designer Studio, under Cluster Management tab, we can see only one node. Second node is not displaying there. In our lower enviourment, I can see two nodes in PEGA but in Prod , only one is visible.
I have compared prconfig.xml for nodes in SMA for both the enviourments and it is same, so nothing is getting setup via prconfig.xml. Is it something related to LB or pega configuration?
Please help.
