Tsys
Last activity: 25 Sep 2017 4:59 EDT
PEGA Deployment using JenKins in Multi-Tenant Environment
We are making use of Multi-Tenancy in our current project.
Can anyone help me out with an article or any material as to how to automate deployment via Jenkins in multi-tenant environment. Any help would be highly appreciated.
Adding to Vikash shared information, you need to download the specific prpcServiceUtils.zip file from the location specified by vikash and this feature is available for Pega 7.2.1 onwards.
Tsys
Hi Mahesh,
We are already through with all these. All I need information is how to implement in a multi-tenant environment.
Tsys
HI Vikash,
I have implemented following step by step procedure mentioned in article(first link of your reply). Its no where mentioned about how this can be achieved in an environment practicing multi-Tenancy.
Coforge DPA
I have installed personal edition of 7.2.1. But I want to implement multi tenancy. So can anyone help me by providing step by step procedure on how to implement it.
Thanks.
Hi Mansil,
I am not clear about your requirement, so you are looking for help to install it as Multitenant system or you are looking help to implement the export/import functionality using Jenkins from one environment to another?
Regards
Mahesh
Virtusa IT Consulting
AE
I doubt multitenancy can be achieved on personal edition, you have to go for full media version and select multitenant option before installation.
Coforge DPA
Hi Mahesh,
What my plan is to have an local environment which can be accessed by different users where the application treats them as different entities, providing them separate applications and Databases, similar to Multi-Tenancy.
Is this possible?
Mansi
@Mansil, Basically an environment will need the server and database to install Pega product. Now each application which is created in this environment will internally create the corresponding 4 users i.e. Admin, Manager, Auditor and User. And all the applications which are created in this environment will be stored in the same database.
Now if you want multiple independent environments then you need to perform multiple Pega installations with new server and database.
So i am really confused what exactly you are trying to achieve.
Hi Astha,
You can refer below links for your requirements:
https://collaborate.pega.com/question/using-prpcserviceutils-and-jenkins-automated-application-deployment
https://pdn.pega.com/forums/prpc/testing-applications/how-to-invoke-prpc-test-suites-from-jenkins-job.
Vikash
