Pega API [POST] is creating a case even if there was an error in the transaction
Pega API 7.2 is being used to create cases and sometimes the response is an error, however, case gets created. This behaviour is causing duplicated cases from the business side since when the error is returned, the external system recalls. Pega is deployed in a cluster and what we have noticed is that this error only occurs in cluster.
Error returned is: Pega_API_014: .pyCommitError: ** ** ORA-00001: unique constraint (DATAADM.PC_HISTORY_CCC_NN_YY_WORK_PK) violated
Is there any mechanism to avoid creating the case when an error is returned?
