Pega 7.2.2 - Installing Hotfix Via "prpcUtils.sh import" Errors
I am currently trying to install a hotfix via the "prpcUtils.sh import" utility in a Pega 7.22 instance on a fresh database. Importing it manually has worked but unfortunately every time that I try and import a hotfix using the prpcUtils I receive the following stacktrace root error (stacktrace is attached): java.lang.IllegalArgumentException: Unrecognized parameter '-T'
I have been able to upload zip files (i.e. PegaRoboticsConsole) via this mechanism with the import.mode="import" instead of "hotfix".
Has anyone come across this before?
Elliot
p.s. I have redacted some information (i.e. Passwords, IP addresses) from the uploaded files
