PDF Format Not Correct
hi, may i know if anyone encounter pdf format is not consistent before? Or is there a way to modify the pdf format.
@WeiPingT did you go through the articles we suggested?
In particular this one and this one?
Can you try this :
To use the compact style sheet, enable the UseCompactStylesforPDF dynamic system setting by performing the following steps:
true.Please check that you have the same hotfixes installed on both environments.
Also check what version of PD4ML you have installed.
Our latest 8.7 Pega version has 4.0.13 pd4ml jar included.
Can you try this :
If you need further help I suggest that you log a support incident for this. Please provide the INC reference here so that we can help track it.
@WeiPingT please have a look at all the available resources on the Pega Support Center and Pega Academy pages:
https://support.pega.com/support-doc/troubleshooting-document-attachment-issues-pdf-inline-preview
https://support.pega.com/support-doc/troubleshooting-html-pdf-conversion-issues
https://docs-previous.pega.com/pega-services-troubleshooting/updates-pd4ml-support
https://docs-previous.pega.com/user-experience/86/setting-pdf-file-versions
https://academy.pega.com/topic/pdf-automation/v1?check_logged_in=1
https://support.pega.com/support-doc/video-how-troublehoot-blank-pdf-issues
https://wiki.pega.com/index.php/PDF_document_generation_patterns
hihi, my version is 8.6.5 and the pdf format one is in grey color background in UAT and one is in white color back ground in dev. The alignment of the check box is also off
Can you try this :
Can you try this :
