The operators for KPIs for Marketing Campaign are not working as intended
When I create a campaign and provide goals for the same, Pega Marketing user guide says that the operator displayed between the goal field and the target value should automatically toggle (between >= and <=) depending on whether higher or lower performance of the goal metric is the desirable result. For example, the Outbound Conversion Rate goal utilizes the >= operator while the Decline Rate goal utilizes the <= operator.
But unfortunately, it is not working as intended, and the operator stays fixed at >= irrespective of the goal that I select. For a goal like Decline Rate, >= operator does not make any sense. If anyone has any clue why is it happening like that, or if there are any hotfixes available , please let me know.
Pega Marketing version --> 7.22
Pega version --> 7.2.2
Thanks in advance.
