Standard Chartered Bank India Branch
Open Span Object Explorer (Shared)
Can you please let us know if the Object Explorer can be utilised in a Shared /common way.
We have an application with the same source code across 40 countries , We tried with Openspan and interrogated the objects for one country , however
that same object explorer could not been used by the other country (with the same source code only the URL different) , can you please let us know if there is a solution in place.
Capturing the Object repository for all the countries with the same source code will be a Duplication and tedious task.
Kindly let us know if there is a work around for this constraint
If the only thing that is different is the URL, then you can probably just change your match rules to address the change in URL.
On the parent control, what are your match rules?
