Morgan Stanley
Last activity: 14 Jul 2022 12:33 EDT
Open Non default portal harness using url in full portal mode
Requirement: Pega version is 8.5.1
When user logs into the application or launches application url from email, a default portal is launched with a default portal harness(usually first navigation item maps to the same harness).
How to create a URL that opens the portal but launches a non-default navigation item(non-default hanress)?
Attempted Solution:
Written a custom activity(Ex:named ShowCustom) that calls doUIAction and pass the Harness name as parameter along with other parameters that harness needs to load properly.
create the url as below:
https://<host>:<port>/PRServletCustom?pyActivity=ShowCustom
It is opening the harness, however not opening it as part of portal, so Header and navigation or not loaded.
Tried Snapstart url too, it did not seem to work.
Question:
I need a way to open a particular harness(page) of a portal through url in full portal mode.
As we embed the url in email, user launches a particluar page(harness) but should have the ability to move to other pages and logoout, etc as well.
