How to launch a specific harness with full portal using Snap Start
When user logs in, the defaulted landing page is "My Work" as below.
I want to launch other harness, such as Pulse only when accessed via different URL. For this, I have tried Snap Start. I thought "showHarness" may work for this purpose. Please see below help for the syntax.
If I understand correctly, the Snap Start string should look like:
However, when I enter above string in the URL, I got below error.
According to the error, it seems to be looking for @baseclass, instead of Data-Portal class.
Another attempt I tried is using doUIAction activity. I have created an activity under @baseclass, named "ShowCustomHarness" and configured it as below.
Then I tried below URL:
This time, I was able to open Data-Portal.pyPulse harness, but without full portal. This is not what I want.. I want an entire portal just like when I normally log in to the system.
Actually I found the same questions on Pega Community, but none of them were answered. Can anyone please let me know a solution?
https://collaborate.pega.com/question/open-non-default-portal-harness-using-url-full-portal-mode
https://collaborate.pega.com/question/snapstart-url-not-displaying-harness
I too tried similar way and getting similar issue that you are facing.
Any help to resolve the issue will be very helpful
