Open Cases in separate tabs once clicked from Workbasket
Hi ,
I have a requirement of opening the cases in different tabs when we are clicking from workbasket. That is once you log into the portal, click on a required workbasket and then click on a case which you need to open. The case must open in a separate tab and the workbasket should remain opened in the previous tab. This should happen till 6 tabs are opened.
Please let me know if I could do this using any OOTB rule.?
