Need Info on-Best Practice on what agent configuration in multi host/muti node environment for Pega 7
Hi All
Here is the scenario. There are ~ 50 agents OOTB in pega 7.1.7/7.18. We multi node environment in production ( 64 jvms). We want to know basic answers to questions like
Do we need to run this agent on all JVMs(ex: System pulse) or it can be enabled only on one or few nodes(Fr example: if it’s a maintenance agent for doing housekeeping at DB side, we don’t need it on all JVMs).
We were pointed by SR folks to links like https://pdn.pega.com/system-operations/running-agents-on-a-multi-node-system which does not have specific info we are looking for.
For example : AgentBulkProcessing need not to run on every JVM , same with System cleaner. Where as System Pulse could/should run on each JVM
We are looking for what is the pegasystems recommendation on how their OOTB agents should be setup in multi node environment. Some documentation around it.
Any info is very much appreciated!!!
Hi All
| RuleSet | # | Description |
| Pega-ProCom | 0 | ServiceLevelEvents |
| Pega-ProCom | 1 | AgentBulkProcessing |
| Pega-ProCom | 2 | SendCorr |
| Pega-ProCom | 3 | GetConvertedPDFsFromPDM |
| Pega-ProCom | 4 | GenerateStartingFlows |
| PegaAESRemote | 0 | InitializeHealthInfo |
| PegaAESRemote | 1 | PushLogUsageData |
| PegaAESRemote | 2 | PushDBIndexes |
| PegaAESRemote | 3 | PushGuardrailData |
| Pega-ProcessEngine | 0 | AgentCaseBulkProcessing |
| Pega-ProcessEngine | 1 | ProcessCaseTypeCalculations |
| Pega-ProcessEngine | 2 | ProcessEmailRequest |
| Pega-ProcessEngine | 3 | ProcessFlowDependencies |
| Pega-RulesEngine | 0 | PurgeAssemblyDatabaseCache |
| Pega-RulesEngine | 1 | ScheduledTaskProcessor |
| Pega-RulesEngine | 2 | PropertyOptimization |
| Pega-RulesEngine | 3 | DeleteUnusedCSSFiles |
| Pega-RulesEngine | 4 | ReportStatUsageAgent |
| Pega-RulesEngine | 5 | UpdateActiveNonQuiesceAdminRequestors |
| Pega-RulesEngine | 6 | DeleteUnusedStaticContentFiles |
| Pega-RULES | 0 | SystemCleaner |
| Pega-RULES | 1 | SystemPulse |
| Pega-RULES | 2 | SystemIndexer |
| Pega-RULES | 3 | RuleUsageSnapshot |
| Pega-RULES | 4 | StaticContentCleaner |
| Pega-RULES | 5 | SystemWorkIndexer |
| Pega-EventProcessing | 0 | SystemEventEvaluation |
| Pega-AppDefinition | 0 | PostAction |
| Pega-AppDefinition | 1 | CreatePMFItem |
| Pega-AppDefinition | 2 | UpdatePMFItem |
| Pega-ImportExport | 0 | @baseclass pzInstallation |
| Pega-RuleRefactoring | 0 | Refactor Copy/Move/Merge |
| Pega-SecurityVA | 0 | Rule Analyzer |
| Pega-DecisionEngine | 0 | UpdateAdaptiveModels |
| Pega-DecisionEngine | 1 | ProcessBatchJob |
| Pega-DecisionEngine | 2 | ADMSnapshot |
| Pega-AutoTest | 0 | RunTestSuitesFromAgent |
| Pega-AutoTest | 1 | RunRecursiveTestSuites |
| Pega-IntSvcs | 0 | checkPrintErrors |
| Pega-IntSvcs | 1 | checkFaxErrors |
| Pega-IntSvcs | 2 | purgeRequestsTable |
| Pega-IntSvcs | 3 | ProcessServiceQueue |
| Pega-IntSvcs | 4 | ProcessConnectQueue |
| Pega-IntegrationEngine | 0 | pyCleanupWebSSO1 |
| Pega-IntegrationEngine | 1 | pyCleanupWebSSO2 |
| Pega-IntegrationEngine | 2 | pyCleanupWebSSO3 |
| Pega-IntegrationEngine | 3 | pyCleanupReplayCache |
| Pega-EndUserUI | 0 | DeleteOrphanTags |
| Pega-EndUserUI | 1 | PurgeExtraRecents |
| Pega-EndUserUI | 2 | PurgeRecentReports |
Manoj
Message was edited by: Vidyaranjan Av
