Mercedes Benz Mobility
DE
Last activity: 6 Sep 2018 5:50 EDT
Pega environment Issue - Multi node
We are facing an issue with Dev environment, which has two nodes. Issue is - whenever a rule is modified in node1 and checked in. The same changes are not reflected in node2.
If anyone of you, faced the same issue. Can you please let us know the steps to resolve it.
Thanks, - S Ch Avinash
PEG
The behaviour in this respect is dependent on the version.
Which version are you using?
DE
PPRC V7.1.8 with CPM 7.1.3
suneratech
Hello Avinash,
Are you guys pointing the same DB to other nodes? This should work, if you made any changes in node 1 it should effect in node 2 too.
DE
Hi Naveen,
Yes, we are pointing both the nodes to same DB. Still there is this issue.
PL
It can be a problem with hazelcast protocol. Do you have Load Balancer behind these two servers? Could you please check table called pegadata.pr_sys_statusnodes. You should have there a list of nodes that working in cluster. If you do not see there all nodes it means that there is miss-configuration.
PL
Hello Avinash,
One more question: Is it happens with all the rules or only for specific one? Could you provide that details?
PEG
Also please check that your SystemPulse agent is running on both nodes
DE
I have checked both nodes and SystemPulse agent is running for every 60sec.
DE
Till now, I was able to find this issue is happening for below rule types,
decision table, activities and data transforms.
I suspect, there are no specific rules. It might be happening for all rules.
DE
Hi Jakub,
Yes, there are records related to node details are present in the pegadata.pr_sys_statusnodes table. please find below screenshot.
PEG
Additionally, you may want to check whether you have the following hotfix installed: -
HFix-24850
And potentially
HFix-25409
HFix-45466
Coforge
Below link might help you.
https://collaborate.pega.com/question/rule-cache-not-sync-multi-node-environment
