Need clarification on this article
I am trying to run these steps on a linux based Pega install. Does anyone have the correct syntax to run step 6 of these steps in a Linux environment (this is also a Pega 7.1.9 environment not 7.1.5 if that matters)
Step 6: Edit install.bat to install only UDF
Then you can edit line 53 of install.bat to call this new target or just set ant_home and java_home and make the call from the command line.
call "%ANT_HOME%\bin\ant.bat" %ANT_PROPS% -f setupDatabase.xml installUDF
https://pdn.pega.com/support-articles/report-definition-displaying-wrong-data-unexposed-properties
Node ID: 268986
SA ID: SA-4980
