Lloyds Technology Centre
Last activity: 13 Mar 2019 10:41 EDT
Need clarification on prutils.properties execution
To populate the data into the newly added/exposed column in the work table, we are following the Pega recommended approach "Database Column populator" by updating prutils.properties file as advised in the below post:
https://community.pega.com/sites/default/files/help_v74/procomhelpmain.htm
However, we encountered an issue as below:
[echo] ****************************************************************************************************************** [echo] Performing 'expose' on system using properties /opt/applications/pega/cicd-base-sd-hfix/scripts/utils/prpcUtils.properties failed.
[echo] Cause:
[echo] The following error occurred while executing this line:
[echo] /opt/applications/pega/cicd-base-sd-hfix/scripts/utils/prpcUtils.xml:277: src '/opt/applications/pega/cicd-base-sd-hfix/archives/pegadbinstall-classes.zip' doesn't exist.
[echo] Cause:
Pega support reviewed the issue and confirmed that '/archives/pegadbinstall-classes.zip' is missing and advised to request for Pega 7.2 media file. We got the Pega 7.2 media file, but it is more than 3.2 GB in size and it contain lot of files along with 'Archives' folder which was missing as per above error. As we have some space constraints to move from one environment to another environment (using BitBucket/UDeploy process), wanted to understand what are all the files we can consider to execute prutils.properties file successfully.
We also notice that this pega 7.2 media file have 'rules' folder which has 'PRPC_Rules.jar (2.21GB in size)', 'PRPC_Data.jar (336KB in size)', 'SysConfigTemplates.jar (6KB in size)'. Can we ignore these files from this media file to migrate to higher environments?
Please clarify.
Kiran Etikela
Hi Kiran,
prpcUtils is referencing prpcUtils.xml. If you look into prpcUtils.xml you can see it does require pegadbinstall-classes.zip and prweb.war
