Hexaware Technologies Ltd
Last activity: 18 Sep 2020 8:28 EDT
In multiple case creation populate particular data from Pagelist to topcasepage of newly created case
Hi Team,
I have a requirement to create multiple case based on pagelist data. For that i have used split-for-each shape inside that i called the process flow which have create case smart shape to create the cases. Through this i can able to create the multiple cases. For example Pagelist - MultiInsured has 3 records then three case will be created, the pyID of cases are stored in pyTopCasePage,pyTopCasePage_1,pyTopCasePage_2 .
My query is, how to pass the MultiInsured(1) data to pyTopCasePage
MultiInsured(2) data to pyTopCasePage_1
MultiInsured(3) data to pyTopCasePage_2 in dynamically using DataTranform.
I have also attached the clipboard view on the same. Faster response will be appreciated.
Thank you,
Uma
